I want to use a PXIe-6341 and SCB-68A connector block to take NRSE readings of several analog signals with a shared ground (which I don't want to connect directly to AI GND). I need to make two connections to AI SENSE: my test item's ground, and a bias resistor to AI GND. My question is, are there any pads inside the SCB-68A that connect to AI SENSE, or do I have to make both of these connections in the AI SENSE screw terminal? I feel like combining a solid resistor lead and a stranded wire in the terminal block would be bad practice. The SCB-68A manual alludes to connecting circuits in the "custom breadboard area" to AI SENSE, but (unlike the well-documented AI n+ and AI n- biasing/conditioning areas) it doesn't give any indication of what pads, if any, you could use to do this. Thanks.
