Multifunction DAQ
SCB-68 & M-Series PCI-6221
I have a PCI-6221 M series (68PIN) that I want to connect to SCB-68
The manual that came with the SCB-68 (under Quick REference labales) does not show M Series Devices!
It only shows, E,S, 670X671X/673X,660X,653X and 7811R/7831R Devices.
Any idea where do I find the information for the M series devices?
Thank you
(3,386 Views)
The device pin-outs given in this manual for your  PCI-6221 should match with your SCB 68 pin numbers.
As far as i know, the switch settings on SCB 68 has not changed for M series.
Plus your MAX also shows the device pinouts.
Go to device and interfaces, click on your card and select  for device pinouts from the drop-down menu.
hope this helps
Regards
Dev
(3,385 Views)
Hi All-
You can find quick reference labels for most other 68 pin cards here.
Hopefully this helps-
Tom W
(3,356 Views)
