05-18-2006 12:43 PM
05-19-2006 10:51 AM
Hello David,
This DAQ message is expected when you specify a sampling rate that is above the
maximum sampling rate of your device. The PCI-6221 has a maximum sampling
rate of 250 kS/s for a single channel. If you have more than 1 channel
this max rate will decrease. For example for 5 channels you will have a
max sampling rate of 50 kS/s. If this is not fast enough for your
application, you might want to look into the high speed data acquisition
products such as our High Speed M Series devices. These are capable of a
1M aggregate sampling rate.
Jesse O.
Applications Engineering
National Instruments.
