10-17-2012 05:01 AM
Hi All,
My application is set up to synchronously and continiously process two analog input channels and generate two analog output voltages.
The application works perfectly but have some problems with a small addition I try to make.
What I am trying to implement now is a simple stop trigger which simultaneously resets both AO channels to 0 V.
The stop trigger should come from a simple switch connected to the PFI0 channel of my BNC-2090 / DAQcard 6024E system.
This will just serve as an extra safety measure on top of some more reliable ones already implemented.
Following different KnowledgeBase articles and examples I found I came up with the design as attached.
While it does stop the data acquisition and terminates running of the application it doesn't reset the AO to 0 (it stays on the last value set).
Any help would be much appreciated.
Mark
10-17-2012 07:04 AM - edited 10-17-2012 07:05 AM
The simplest solution would be to write 0 to the AOs before clearing the task. The empty array of waveforms will not work. You need to have actual data. And since you are only applying the single 0V, you can use the single sample 1D array to write the 0s.
10-17-2012 07:29 AM
I tried this, but unfortunately it still doesn't get back to 0. Moving it before clearing the AI task also doesn't work.
Any explanation for this? (So the lower task line is the AO - the upper the AI)
Thanks (see below the way I build it),
10-17-2012 07:40 AM
I think I see the problem. The AO task is set to "sample" on the AI's sample clock. If the AI clock isn't running (via the task being cleared), then the "clearing" sample will never be outputted. You need to write the 0V before clearing the AI task.
10-17-2012 08:03 AM - edited 10-17-2012 08:04 AM
Yeah that makes sense and I tried it, but again no luck.
It seems however that when I start running the application it shortly gets back to 0V before data acquisition starts.
Might be a problem of order of execution? (Although I always thought a DAQmx block wouldn't start before all connected lines are active, so data, error and task line).
Tried the flat sequence, but that doesn't work.
Mark
10-18-2012 07:06 AM
Hi Mark,
Would it be possible to use a "stop task.vi" function then setting the new writes and then using a "start task.vi" before clearing after your loop? This way you can be clear that the original AO task has stopped executing before changing the values being generated.
Kind Regards,
10-22-2012 07:17 AM - edited 10-22-2012 07:18 AM
Thanks, copy of the solution below.
Appreciate the help!
Mark
