Multifunction DAQ
Replacing one NIDAQPad-6016 by another
When replacing one NIDAQPad-6016 by another one it is not possible to take over the once installed DAQmx-Tasks. Why?
(2,624 Views)
As long as the same device names are assigned for both boards (e. g. "Dev1") I wouldn't assume that a problem occurrs. What are the symptoms?
Jochen Klier
National Instruments Germany
(2,618 Views)
When connecting the new NIDAQPad on USB the system detected a new hardware and installed the software regardless of the allready installed software. In MAX the new NIDAQPad appears as Dev2 with a different Ser.-No.
(2,608 Views)
That's expected and normal behavior. As long as you don't remove the first DAQPad from MAX another DAQPad will be recognized as a different device and the driver assigns a new device ID (Dev2). You need to go to MAX and change the name if needed or you need to make your software try various device IDs until no error occurrs anymore.
Jochen Klier
(2,604 Views)
