12-21-2015 10:55 AM
New to the forum, so bear with me if I'm in the wrong spot.
I have a system using a PCI-6220 board, and I am considering upgrading the computer being used. If I decide to do so, then I would like to upgrade the board as well. According to the NI product information, the PCI-6220 can be replaced with the PCIe-6320. I am concerned about the mapping of the I/O on the board though, and was wondering if anyone else has had experience with this. I need to know if I would have to change the LabView code to accommodate the new board, or if it would be a drop-in replacement that will just work.
Thanks!
Solved! Go to Solution.
12-21-2015 11:01 AM
Dig through the specification documents (6220, 6320). You will see that the pinouts are exactly the same.
12-22-2015 08:21 AM
Thank you, crossrulz, for the response. I looked into the data sheets as you suggested and found what I was looking for. The part number for the board turned out to be PCI-6221 and the replacement PCIe-6321 has the same pinout. This board is connected to a SC-2345 Signal Conditioning Connector Block. Since the pinouts for the two boards are the same, do you expect there to be any issues with the interaction with the SC-2345?
12-22-2015 08:24 AM
Not at all. NI tends to keep things mostly the same between boards so that they can reuse connector blocks.
10-20-2020 08:28 AM
Hope you can help. I made the same replacement when a new computer had the PCIe slots. My problem is NI MAX recognizes the PCIe6320 card but when I create the SC-2345 front end, it populates into the Devices and Interfaces with a '0:' in front of the name and when I go to test it in NI MAX, I get a commuications error. I know that additional '0:' in front of 'NI SC-2345 "SCC1"' must mean something, but there is no where in the literature that addresses it.
I have repeatedly checked the configuration of the SC-2345.
Cable is black and on the side
Digitizer is PCIe 6320
Power is PWR2, since NI configured it with a Universal Power Supply
The box has 6 ACC01 modules and one AI01 module
There are no outputs since this is a 6320 card. The replaced card was a 6221, but again, there were no outputs.
This is terribly frustrating and NI will not help without a contract for technical support.
Ron
rbrook@ips.us
