Multifunction DAQ
Repetitively triggered AO
I have a train of TTL pulses (30ms long, 2 ms apart) coming in. Triggered by this signal, I would like to alternate an AO between 2V and 0V: One DI pulse should put out 2V, the next 0V, ...
I found an example on how to trigger an AO waveform but I cannot retrigger it. I know the exact length of the pulses, I just want to use the rising edge to start the AO signal. I guess I am looking for the functionality of a counter for an analog output.
I have a PCI-6733 and Labview 8.5.1. The two counters on the board are already in use but I could free one if that helps.
Thanks for any suggestion!
Jan
(3,429 Views)
Accepted by janhui
From the above behavior it seems the input DI pulse is a Sample Clock signal and not a trigger.
(3,425 Views)
Thanks! I just tried 'Cont Gen Voltage Wfm-Ext Clk.vi' which seems to get the job done! I did not know about the Sample Clock...
(3,405 Views)
