06-22-2015 07:26 AM
I need to control the on off cycles of a basic 5v 50mW laser via my myDaq. I found a tutorial on the NI website wich recommended a certain solid state relay from cycling the power of a 12v fan, but that relay is no longer available. Does anyone have a recommendation of where I should look?
06-23-2015 05:15 PM
Hello Aboyd656,
Please could you give more information on the NI website tutorial, and which relay it recommended? To see which other product we can recommend you.
06-24-2015 07:55 AM
06-24-2015 08:18 AM - edited 06-24-2015 08:18 AM
ONe way:
Go to digikey
http://www.digikey.com/product-search/en/relays/solid-state-relays
and filter for voltage input and output type
order or select a type and search the web for a distributor of your choice.
