04-20-2021 03:47 AM
I wish to perform Multichannel Analog out DAQmx using PXIe-4322.
I wish to know recommended guidelines for Multichannel Analog Out DAQmx.
I attached simulated DAQ code
-for 1 channel 1 sample based 2 Analog out channel as well as
-for N channel 1 sample based 2 Analog out channel.
kindly explore pros and cons for the both codes.
The objective of this question is :
if I am using N Channel-1 Sample configuration, when I am writing AO0 channel with new data, why should I write AO1 channel same value also.
Example:
Initially AO 0=1.2V, AO 1=0.7V, array is writing to their corresponding channel.
later i wish to change AO 0 alone with new value of 1.69V. at that time, Both AO 0= 1.69V and AO1=0.7V are writing.
is that correct/recommended one?
any Task creation will cause any issue?
04-20-2021 07:55 PM
Here's some brief notes that come to mind about the tradeoffs:
2 tasks, 1 channel each
Pros:
Cons:
1 task, 2 channels
Pros:
Cons:
-Kevin P
(Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
