Recommended Guidelines Multichannel Analog out DAQmX
I wish to perform Multichannel Analog out DAQmx using PXIe-4322.
I wish to know recommended guidelines for Multichannel Analog Out DAQmx.
I attached simulated  DAQ code
-for 1 channel 1 sample based   2 Analog out channel as well as
-for N channel 1 sample based   2 Analog out channel.
kindly explore pros and cons for the both codes.
The objective of this question is :
if I am using N Channel-1 Sample  configuration, when I am writing AO0 channel with new data, why should I write AO1 channel same value  also.
Example:
Initially AO 0=1.2V, AO 1=0.7V, array is  writing to their corresponding channel.
later i wish to change AO 0 alone with new value of 1.69V. at that time, Both AO 0= 1.69V and AO1=0.7V are writing.
is that correct/recommended one?
any Task creation will cause any issue?
(306 Views)
Here's some brief notes that come to mind about the tradeoffs:
2 tasks, 1 channel each
Pros:
  • write to either channel any time without needing to also write to the other
Cons:
  • can only use software timing for updates
  • cannot update both channels in sync with one another
1 task, 2 channels
Pros:
  • can generate waveforms with hardware-precise timing
  • both channels can be updated in sync with one another
Cons:
  • must write data for both channels, even if only 1 is changing
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW?
(Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(262 Views)
