07-25-2012 03:49 PM
I am running a Matlab script for real-time PID control of a basic system at a 100Hz sampling rate. When using the DAQcard 6062E, the control loop easily operates at 100Hz (probably capable of 200Hz). I need more digital outputs than the DAQcard can offer, so I am investigating the use of a cDAQ-9174 (with NI-9403 DIO module and NI-9205 AI modules) that we have onsite. Unfortunately, I can only get the cDAQ to operate the same loop at 20Hz.
The basic structure of my script is:
- Configure task
- Begin control loop
- Read AI's (1 sample per channel)
- Compute PID value
- Write DO's
- Wait for next sample clock
- Repeat loop
Could the slower sampling rate of the cDAQ just be due to the USB connection, as opposed to the PCMCIA-connected DAQcard? Or, could it be something else? I did need to change 2 things in the Task Configuration just to make the script work with the cDAQ:
1) I added the DAQmxSetSampTimingEngine function in the cDAQ script to set the clock to be the "ai" clock. I could not get the DAQmxCfgSampClkTiming function on the next line to work without setting the timing engine.
I did not have to set the timing engine in the DAQcard script, I assume because the timer and all AI's and DO's belong to the same device name. (?)
2) I could not use "HWTimedSinglePoint" as the sampleMode in the DAQmxCfgSampClkTiming function. I get the following error:
DAQmx error - Requested value is not a supported value for
this property. The property value may be invalid because it
conflicts with another property.
So, I had to use DAQmx_Val_FiniteSamps to allow the script to work. I set the number of samples per channel to 2 (which I think is the minimum allowable for DAQmx_Val_FiniteSamps), and only used the first sample.
I understand there is hardware and software to make real-time running more robust, but at only a 100Hz sample rate, I am hoping to get by with something as simple and straightforward as the Matlab/DAQcard system that I have, whether it be the cDAQ, or one of the newer portable DAQ's.
Any help is greatly appreciated!
Paul
