Reading analog signal by NIcDAQ and monitor it at CANape interface
I have a NI cDAQ-9174 and Vector CANape. I'd like to add the signal read from NI cDAQ to the CANape interface, so I can monitor the CAN signal and analog signal(from cDAQ) at the same time.
Here is the very basic test, I'm feeding a sinewave to the cDAQ. NI MAX shows the signal is readable, but once I add it into CANape. It shows the error below "NI-DAQmax:Task mode not supported -a0_voltage-".
Does anyone know the reason?
(771 Views)
Did you got the solution?
Can you tell me how to  access 9211A NiDAQmx in Vector Canape
(402 Views)
