09-10-2019 11:33 AM - edited 09-10-2019 11:35 AM
I am having some troubles reading a BPW34 with a with PCI-6251 and BNC 2110. I connected the diode directly to the BNC board AI0 connector and I am monitoring the signal with LabView. However, the signal is not as smooth as the one I see when I connect the the diode directly to an oscilloscope. How can I improve the reading on the NI board? Should I amplify the photodiode?
09-10-2019 11:04 PM
Hi gibbsphe,
You mentioned BPW34 was directly connected to AI0, which slot did BPW34's negative connected to? Did you select corresponding terminal configuration in "DAQmx create channel"?
I would suggest you choose differential configuration, and AI0/AI8 would be differential +/- inputs (AI1/AI9, AI2/AI10 and so on).
