Multifunction DAQ
Read voltage and process realtime.
I have a PCI-6251 DAQ card and the DAQ Documentation and SW Combo kit.
I would like to write a Visual C++ program to read an analog voltage and process that voltage realtime.
I noticed the function DAQmxReadAnalogF64.  But it seams that I can only process the readArray after it is filled.
How do I read one analog input sample?  So that I can process it immediately.
Kevin
(2,697 Views)
Why don't you just use 1 for the numSampsPerChan?   I have to warn you though if you do that you won't be able to run at very fast rates in your application.
StuartG
(2,687 Views)
Hi Kevin,
Just to add to Stuart's suggestion, please take a look at the DAQmx C examples that install with the driver located at C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C on your computer.  In particular, navigate to Analog In >> Measure Slow Varying Signal >> One Sample.
Thanks!
Laura
(2,675 Views)
