Multifunction DAQ
RTSI for PCI 6123
Hello all
              I want to connect four PCI 6123 via RTSI cable.Kindly tell me in which direction i should insert RTSI female connector into PCI 6123 male connector since it can be fitted in both directions (RTSI cabe red side inward or outwrds )?
Best Regards
ASIM
(3,201 Views)
Hey ASIM,
The RTSI cable is 1 to 1 cable hence it really doesn't matter which way you connect. But the Pinout depends on what type of card you are connecting i.e. AT or PCI cards. Here is the pinouts and this knowledgebase will tell you how can you configure it.
-lab
(3,173 Views)
