05-15-2014 04:37 PM
I am trying to read an analog input of 0-5V from my flow meter, Omega FMA-1605A. I connected the communication wires to the RS-232 port on my USB to RS-232 adapter that is connected to the computerw. But when I try to set up a DAQ read task, it says "No supported devices found."
What can I do to fix this? Should I try using the PXI-6239 card I am using to read analog current signals to read the analog voltage?
Thank you!
Amanda
05-15-2014 04:53 PM
05-16-2014 07:13 AM - last edited on 05-06-2024 03:47 PM by Content Cleaner
If you want to use a DAQmx task, then you have to use an NI DAQ device. A simple one like this might work for you: USB-6000
05-16-2014 11:07 AM - last edited on 05-06-2024 03:47 PM by Content Cleaner
You can use the NI-VISA driver to communicate with the Omega device via RS232. Serial communication works by sending device-specific commands. The commands are likely listed in the Omega device's manual. The PXI-6239 is an analog input module, so you can wire signals into the channels. I'm not familiar with the Omega device, so I don't know is it has analog output channels to input to the analog input channels on the PXI board. Most likely you will be using NI-VISA to send and receive messages with the Omega device.
