Multifunction DAQ
Qt linker issues with NIDaqMX
Very basic question but I couldn't find the solution after searching online for several hours.
I'm running NIDaqMX 14.1 in Windows 7 64-bit (although the NIDAQmx is installed in Program Files (x86)). I'm trying to interface with a PCIe-6353 with Qt Creator 3.4.2 (Based on Qt 5.5.0 (MSVC 2013, 32 bit). I included the nidaqmx.lib in the .pro file but I get LNK2019 messages for unresolved externals for all of the NI commands. The code and project file are below:
Does the NI library only work with mingw and not msvc?
#include <QCoreApplication>
#include "C:\Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.h"
int main(int argc, char *argv[])
    TaskHandle taskHandle;
    int error;
    // DAQmx analog voltage channel and timing parameters
    error = DAQmxCreateTask("", &taskHandle);
//    error = DAQmxCreateAOVoltageChan(taskHandle,"Dev3/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL);
    DAQmxStopTask(taskHandle);
    DAQmxClearTask(taskHandle);
    QCoreApplication a(argc, argv);
    return a.exec();
The .pro file is as follows
QT       += core
QT       -= gui
TARGET = untitled
CONFIG   += console
CONFIG   -= app_bundle
TEMPLATE = app
HEADERS += "C:\Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.h"
LIBS += "C:\Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc\NIDAQmx.lib"
SOURCES += main.cpp
(7,839 Views)
You can certainly compile code that uses the DAQmx DLL with MSVC---I do it all the time.
I think that library you're trying to link to is a 32-bit library.  Try using the following include and lib dirs:
C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include
C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/lib64/msvc
HTH,
Adam
(7,719 Views)
I am new to QT but am experiencing the same problem described in this thread.
The lib folder
C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc
contains only a lib file and no DLL.
where will my compiler find nidaqmx.dll
(7,242 Views)
Hi cpbandy,
For future reference, I would recommend creating a new forum post so that your questions are not overlooked.
Also, regarding your question, the DAQmx functions are in a static library(.lib) so the dynamic library of the fuctions (.dll) that you're looking for does not exist.
Shalini M.
Partner Development Engineer
Alliance Partner Network
(7,195 Views)
i just linked int my QT project like this
LIBS += -L$$PWD/'../../../../../Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/lib64/msvc/' -lNIDAQmx
and i don't have any error, but when i try to use a function
DAQmxCreateTask("",&taskHandler);
 I have an error "undefined reference to 'DAQmxCreateTask'
Anybody can help me please ?
(3,482 Views)
I have the same problem, did you fix yours ?
(3,481 Views)
