Multifunction DAQ
Python using cfg_samp_clk_timing question about 9222 9235 9237
  I use NI cDAQ-9178 include 9222 9235 9237.I want to reduce sample rate to 100-1000. But the 9235 minimum sample rate is 794S/s and the 9237 minimum sample rate is  1613S/s.
How should I do?
(805 Views)
You can resample them in the software to reduce the logging rate, is there a valid reason why the hardware sampling must be that exact range?
Santhosh
Soliton Technologies
(770 Views)
