02-20-2024 04:44 AM
I use NI cDAQ-9178 include 9222 9235 9237.I want to reduce sample rate to 100-1000. But the 9235 minimum sample rate is 794S/s and the 9237 minimum sample rate is 1613S/s.
How should I do?
02-20-2024 09:56 AM
You can resample them in the software to reduce the logging rate, is there a valid reason why the hardware sampling must be that exact range?
