Multifunction DAQ
PyDAQmx and USB-6000/USB-TC01 Thermocouple Device
Hello all,
I am thinking of purchasing the same device for an application of my company. Can somebody verify that the code works/works as supposed?
Message 21 of 27
(2,287 Views)
Here are some useful link that can work for you in the future about
PyDAQmx
https://pythonhosted.org/PyDAQmx/usage.html
This GitHub page is awesome, a lot of examples  https://github.com/ni/nidaqmx-python
Here is an official white paper http://www.ni.com/white-paper/53059/en/ about    NI and Python Resources
Here is a really good pdf https://media.readthedocs.org/pdf/nidaqmx-python/latest/nidaqmx-python.pdf
have a great day.
Message 22 of 27
(2,272 Views)
I conflated the two versions,
One is PyDAQmx  and the other is NI-DAQmx  Python API
Message 23 of 27
(2,257 Views)
I tried to run the script given but I get the following error:
    sensor = NiUsbTC01()
  File "nitc.py", line 33, in __init__
    self.nidaq = ctypes.WinDLL(nidaq_dll_path)
  File "C:\Python35-32\lib\ctypes\__init__.py", line 347, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: [WinError 126] The specified module could not be found
The reason is that I don't have the nicau.dll. How can I get it to run without installing all the nidaqmx runtime?
Cheers!
Message 24 of 27
(2,179 Views)
Unfortunately, you'll indeed need it. Use the commented-out line:
self.nidaq = ctypes.windll.nicaiu
My code from above is incorrect for that matter, since using only the one DLL doesnt work, which I hadnt realized before I tested it on another machine where the runtime wasnt installed.
I also tried to walk down all the dependencies, hoping it'll be just a couple of DLLs that I'd have to add and that it would be portable, but no luck, I finally gave up. But let me know if you can come up with something, it's quite annyoing that you have to install a whopping 300MB software bundle to be able to read out a simple temperature sensor...
Message 25 of 27
(2,173 Views)
Hello all,
In order to run the python script you have to include the absolute file path of nicau.dll (mine is "C:/Windows/SysWOW64/nicaiu.dll").
I attach the code.
Message 26 of 27
(1,905 Views)
Hello All,
Python nidaqmx does support logging from the USB-TC01 thermocouple as task:
import nidaqmx
from nidaqmx.constants import TerminalConfiguration
import time
import threading
import keyboard
from datetime import datetime
start: bool = False
period: float = 0.1 # every 100 ms ??
logTimeInMinutes: int = 1
def measure_thread(taskDev, devName):
now = datetime.now()
fileName = now.strftime("Thermal_Log_%d_%m_%Y_%H_%M_%S")
print(fileName)
directory = "Log/"
fileHandle = open(directory + fileName + ".csv", "w")
fileHandle.write("TimeStamp (ms), " + "TotalMinElapsed (min), "
+ "Temperature (F) " + "\n")
global start
global period
startTimeInMs = time.time()*1000
lastMinElapsed = 0
while start:
# timeStamp = now.strftime("%d:%m:%Y:%H:%M:%S , ")
timeStamp = time.time()*1000 - startTimeInMs
# 60 seconds in a minute, 1000 ms in a second
TotalMinElapsed = timeStamp/(1000*60)
#in Hours
SegmentHourElapsed = (TotalMinElapsed - lastMinElapsed)/60
samples_per_channel = 10
data = taskDev.read(samples_per_channel)
print(f"{data}")
SampleAvg = sum(data)/len(data)
print(f"{SampleAvg}")
strToWrite = (f"{timeStamp:.3f}, {TotalMinElapsed:.6f}, {SampleAvg:.3f},")
fileHandle.write(strToWrite + "\n")
time.sleep(period)
fileHandle.close()
def main():
global start
devName = 'Dev3'
with nidaqmx.Task() as ThermoTaskDev:
ThermoChannel = ThermoTaskDev.ai_channels.add_ai_thrmcpl_chan("Dev3/ai0",
name_to_assign_to_channel="Thermocouple",
min_val=0.0,
max_val=100.0, units=nidaqmx.constants.TemperatureUnits.DEG_F,
thermocouple_type=nidaqmx.constants.ThermocoupleType.K,
cjc_source=nidaqmx.constants.CJCSource.BUILT_IN)
while start is False:
value = input("Enter 's' to Start: ")
if (value == 's'):
start = True
threadHandle = threading.Thread(
target=measure_thread, args=(ThermoTaskDev, devName))
threadHandle.start()
while True:
if keyboard.read_key() == "q":
start = False
break
threadHandle.join()
# Press the green button in the gutter to run the script.
if __name__ == '__main__':
main()
Message 27 of 27
(1,350 Views)
