Multifunction DAQ
Programmatically setting FieldDAQ FD-11601 excitation voltage
DAQmx 18.6
FD-11601
Is there a way to set the excitation voltage of an AI channel for the FD-11601 FieldDAQ programmatically in LabVIEW/DAQmx?  I know this can be done via MAX but we're building our channel list via a config file so we need the ability to set (and enable) the excitation via LabVIEW.
(1,440 Views)
Accepted by topic author DHerron
Nevermind, finally found it buried in the DAQmx Physical Channel property node under Analog Input >> Signal Conditioning >> Sensor Power >> Power Control
(1,424 Views)
