06-17-2019 10:17 AM
DAQmx 18.6
FD-11601
Is there a way to set the excitation voltage of an AI channel for the FD-11601 FieldDAQ programmatically in LabVIEW/DAQmx? I know this can be done via MAX but we're building our channel list via a config file so we need the ability to set (and enable) the excitation via LabVIEW.
Solved! Go to Solution.
06-17-2019 11:23 AM
Nevermind, finally found it buried in the DAQmx Physical Channel property node under Analog Input >> Signal Conditioning >> Sensor Power >> Power Control
