Problem with long Thermocouples and DAQ91xx
Hi
I have a problem measuring the temperature of long thermocouples.
I use a 0.5mm type N thermocouple which is 20 meter long
and a 0.5mm type N thermocouple which is 5 meter long
and two other thermocouples which where about 1 meter long.
I made the test with a DAQ9179 chassis and a 9212-temperature module.
I repeated the test with a DAQ9184 and a 9113-temperature module.
Both Tests give me the same result.
The 20m long Thermocouple shows 24°C and all the other Thermocouples show about 19 °C.
For the Data acquisition I used Signal Express Manager with 50 Hz and 10 Hz (Fast acquisition) and 1Hz (precise acquisition).
I also used a measuring System of iba and a cheap portable measuring instrument and both times ALL the Thermocouples show 19 °C.
Anyone has an idea why this failure appears or has a solution to solve it?
Thank you
(919 Views)
No real ideas, but some suggestions you could try:
Do all the thermocouples have the same construction? Is the long thermocouple Metal-Shethed Mineral-Insulated (MIMI)? Is the sheath touching the thermocouple wires anywhere (a simple resistance measurment will check)?
Are there any Grounding issues?
YOu could try a ferrite bead on the thermocouple wire next to the instrument in case it is an RF pickup problem.
(868 Views)
