07-23-2014 04:47 AM
HeyHey!
For my diploma thesis I need to set up an acceleration controlled shaker experiment.
Therefore I am trying to take my accelerometer (see attachment) into operation with the cDAQ 9174 and the NI 9234. So I am using the DAQ assistant to do so but when I put in the specifications of my sensor I only get a noisy signal with a slide offset from zero even if the sensor stands still. I am not sure about the coupling mode and since the specification says I have to supply the sensor with 5Volt (I can only choose Ampere) I am not sure of that either...
I am process engineer so please explanations for children...
Thank you for any help!
09-02-2014 08:13 AM
Hi NIgery,
I saw that nobody is answering, so I would like to be up to date. What have you done?
Is your question up to date?
best regards
Richard
09-09-2014 04:16 AM
Just by looking at the spec of the sensor:
The output is ratiometric (means: it will change proportional with your supply voltage)
The zero is specified at 0.5Up+-4% (@ 5V ~ +-100mV) , so your zero offset should be in the +-10g range and everything is still OK 😉
What you usually do is a zero offset compensation, measure V_o and when you measure V_a you do a V_comp= V_a - V_o
