11-28-2011 11:53 AM
Hi Justin,
I am new to Labview - could I get some example code to do this?
I have an issue with 6009 that always falls over on Windows 7, I have tried reset the ADC using the reset VI but that does not work. However, enabling and disabling it through device manager does.
Many thanks,
Julian
07-30-2012 03:22 AM
Hi, Is the below part solved?
"5.) The NI 9172 chassis must be reset immediately upon receiving the -50405 error. If self-test is called first, the chassis will have to be unplugged and replugged, this is a software bug on our part that has already been identified."
10-07-2013 04:41 PM
I have the error on a new USB module that I bought mid-2013, same issue as before. Mine is due to environmental noise - in one case, a motor turning on & off, and in another, proximity to a spark gap.
No other devices are having problems, just the USB. It is very sensitive to noise.
Re-routing cables helps, but nothing seems to cure it, not even the use of cables with embedded ferrites.
If anyone has another idea to try, please post. I am recommending that we look into alternatives for future purchases. This problem is maddening.
