Hai all
Thanks in advance.
Processor performance reaches 100 percent.
Testing DAQ6052E card in MAX for continuous mode of acquisition (Traditional DAQ not on DAQmx) causes processor to reach 100 percent
During testing versions are
MAX-3.1.1
NI DAQ-7.4.1f4, 7.4, 7.2 (All these versions leads the same result)
PC-2.4GHz and in PXI-8186-1.7688GHz
RAM-512MB
The same behaviour i observed when i tested 6034E DAQ card under the same above mentioned environment with the same versions.
The same behaviour i observed when i used a LV example program too (Buffered continuous acquisition).
But this behaviour is not present when i tested the DAQ card in DAQmx for continuous mode of acquisition.
See the attached observation in PXI-8186 controller with 1.7GHz processor with 512MB RAM.
