I once used a Kulite miniature pressure transducer. They are really cool!
My recollection (this was like 25 years ago!) is that the one I used consisted of a silicon diaphragm with semiconductor strain gages integrated directly into the diaphragm. The gages were arranged to form a full bridge.
In that case, you would want to connect AI Sense to AI Ground, connect the power supply negative to AI Ground (assuming there isn't anything else that's grounded- be *very* careful). Use Differential input and connect the plus to channel aiN and negative to aiN+8.
The bridge and power supply form a low-impedance path for the bias currents (the reason for the resistor to ground) so you don't need the resistor. The output of the bridge is not at ground, since the power supply at the other corners is grounded, so you have to use differential input.
Now, remember- this was a long time ago
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
