Multifunction DAQ
Pci-6225 with scc-68 and tc02 module on connector 1
  I have a pci-6225 card hooked to a scc-68 with a TC02 module for temperature.  If I connect to connector 0 on the 6225 card everything works ok.  But if I connect to connector 1 I get a floating signal between 100 and 200 instead of the actual temperature.
  I connected the scc-68 to a PCI-6229 card and it works on connector 0 and connector 1 with no problems.  So is there any way to get the scc-68 work on connector 0 on the 6225 card?  The card passes it's self test, so I am trying to figure out what could be wrong with port 1.
Bryan
(3,338 Views)
Accepted by topic author _Bryan
I just figured out why it does not work on connector 1 on the 6225 card.  There is no +5v power on connector 1, only connector 0.
So for a quick test I took the +5v from the scb-68 on connector 0 to power the scc-68 on connector 1, and it seems to work so far.
(3,337 Views)
