I have a PXIe-1071 chassis with a PXIe8361 controller and a PXIe-6537 high speed digital IO board, and we are collecting data from DUT via this system.
When I program the digital IO read/write in Labview, the DAQmx Trigger Property Node does NOT have "Start.Retriggerable" item, as mentioned by others. I also found some other Property Nodes items (as described in the Help document) are not available when I create/edit those nodes in my program. So does this mean my PXLe-6537 card does not support those features?
Thanks in advance!
Rgds,
Harry
