Multifunction DAQ
PXI chassis with DC option
Hi all,
I would like to select a PXI chassis for high sampling data acquisition (4 channel, 2MHz and above).
Are there any recommended PXI chassis with DC battery option so that I can power up the chassis even in the remote area?
Is PXI e-1062Q comes with the DC option?
Thank you.
(4,128 Views)
hyin,
There are DC Chassis that NI makes, such as the PXI-1036DC (6 slot PXI), the PXI-1031DC (4 slot PXI) and the PXIe-1066DC (18 slot PXIe). However, none of these will have any battery built in, they are just designed to be supplied by a DC Source. The closest thing you will get to the 1062 is the 1066, more slots but it's PXIe, which it sounds like you need.
Aaron W.
(4,115 Views)
