Hi, I have got a NI PXI/PCI-5401 Arbitrary Function Generator card which can output voltages of +/-5V into a 50 ohm load and +/- 10V into a high-impedence load. The problem is that with my below attached vi, the maximum output voltage I get is +/-0.05V. If I increase the gain above 10, I get an error message.
If you still haven't been able to get your question answered, I would recommend posting your question in the Signal Generators forum. Someone there would more likely be able to know what is happening:
