Multifunction DAQ
PXI-6224, SCB-68, pressure transducer 9-28vdc power supply
I'm using a SCB-68 connector block to connect a Honeywell FP2000 series pressure transducer to a PXI-6224 DAQ module.  The transducer requires a 9-28vdc power supply, but the connector block seems to only have 5v pinouts.  Do I need to use an additional power supply for the transducer?
(3,996 Views)
Accepted by topic author jdiaz
Yes.
Be sure to connect the ground of the power supply to the AI Gnd of the 6224.
Lynn
(3,993 Views)
