From 11:00 PM CDT Friday, Nov 8 - 2:30 PM CDT Saturday, Nov 9, ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
PWM Acquisition trigged by external signal
Hello.
The goal is to make acquisition of a position sensor PWM signal (500 Hz, duty cycle 10-90%).
An external signal (pulse) is sent by a motor controller in move  each x mm (typ. val x =0.02 mm).
I need to make a measurement (high level time & low level time) at each pulse, considering motor is moving continuously (typ. Speed = 30 mm/sec).
Board used : PCIe 6363
Dev software : Labwindows/CVI 2013 (any help in labview is welcomed too Smiley Wink)
I succeeded in making a PWM Meas with a task CISemiPeriodChan, but not triggered with external signal, so I loose the position of each measurement.
Another solution may be another signal create (with another ctr) to “gate” measurement , but I did not succeed.
I have tried a lot of solution and samples, read a lot of post in forum without an working answer to my problem.
If someone could help me.
Thank you
(3,694 Views)
Hi bicoun,
Did you try to use the DAQmxCfgDigEdgeStartTrig ?
Your device support this property:
NI PCIe-6363 Supported Properties
You can also take a look at the analog measurement (voltage) examples which use this function.
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(3,644 Views)
