10-10-2012 08:25 AM
Hi Folks,
I got a problem with the USB 6009 NI when I connect a PID Controller to an Analog Output in the Simulink.
I would like to know how do I use the PID Controller without select a Discrete-Time in the Time Domain (in the PID Controller Block Configuration), because I need to use a Continuous-Time.
Thank in Advantage.
Best Regards
Pedro Ivo Allevato
10-11-2012 09:12 AM
Hello Pedro,
Based on your picture, I believe you are using the Data Acquisition Toolbox for MATLAB®.This product was created and is currently supported by The MathWorks, Inc. As such, I recommend contacting them with any further questions or issues with this toolbox.
That being said, I found a DAQ in Simulink tutorial that contains your exact error (page 24) and a potential solution (using an Embedded MATLAB function with a PUTSAMPLE operation). Also, you can easily use the USB 6009 to perform PID control using:
LabVIEW PID & Fuzzy Logic Toolkit
MATLAB® is a registered trademark of The MathWorks, Inc. Other product and company names listed are trademarks and trade names of their respective companies.
Andrew Brown
10-14-2012 10:21 PM
Hi Andrew,
Thanks for the reply, I had this Tutorial in which you said, It's fantastic! I've solved this problem using a Zero-Order Hold Block to discretize my signal instead using the Embedded Block, because my Matlab doesn't have this one.
I have one more question, do you have some materials about Level Controller using USB 6009 NI with Matlab (Simulink)?
Thanks in advantage.
Best Regards,
Pedro Allevato
10-15-2012 10:06 PM
Hello Pedro,
The following may be useful:
KnowledgeBase 23KH8MG4:
http://digital.ni.com/public.nsf/allkb/1F8D330AA1DDC7448625699F000168D3
