09-09-2013 12:51 PM
I have a PCIe-6351 that was returned and "fixed" (RMA 7376444) but is having the same problem again it appears anyway. The diagnostic utlility indicates prblems with the Analog input and output. As before it worked for a while and then after not collecting any data or using it over the summer it is not working again. The comuter it is in was only turned on a handful of times. I have not even been able to collect an experiment using htis board because every time I think it is set an work on other aspects of the experiment when I come back to start collecting data the card is no longer working!
I have attached the dianostic utility output file. I need a solution and FAST.
If a different type of board is the answer that is fine I just need to get this fixed. ~$1000 for a card that doesn't work is not acceptable. Please help!
09-10-2013 08:30 AM
Hi Swinges,
I believe we talked about this issue yesterday afternoon. Did you have more questions on your card? Feel free to call back in, if you have more questions on this issue.
