09-15-2007 06:02 PM
09-17-2007 06:16 PM
Hi William,
Make sure you are connecting the DMM to the correct PIN, for example if you are using AO 0; you are going to connect the DMM to pins 34 and 68 as seen in the manual for the PCI-6704 (page 12). Second, make sure that when you are measuring the voltage you are not using the ground of that channel for current output just for now while we are testing the card with the DMM. I would like to know the manufacturer and model of your DMM just make sure it is precise enough to give you a good reading. Can you try more than one channel and check if you get the same response? After trying all the suggestion I have already gave you, you might consider calibrating the card. I know it is a brand new card but it is possible that we need to follow this step.
