Hello!
I have a trouble woth my PCI6052E multifunctional DAQ board. When I perform self-calibration procedure, I give this response:
Running Calibration ... FAILED for the following reason:
Error -200329 occurred at DAQmx Self Calibrate.vi:1
Possible reason(s):
An error has occurred while attempting to configure the device for an analog input acquisition.
If an external master timebase is being used, make sure the source is connected and generating an appropriate clock. Otherwise, contact National Instruments Technical Support.
Can you help me?
Michele
