I've a PCI-MIO-16XE-50 board in a Mac G3 running OS9.0.4 and NI-DAQ 4.9.4. I've written code to toggle the DIO line states which works fine for all but one of the ports output lines configured as output, no handshaking, using NI calls. Has anyone else had experienced this problem? The problematic line is bit 4 (5th line up from LSB)? I performed a readback using DIG_In_Line and DIG_In_Port and both functions return that the lines should be high, but the output is still low.
To check that it wasn't a broken box/board/cable, I repeated the test on another like-configured machine with the same result.
Any clues would be helpful. thanks in advance,
Greg
