Multifunction DAQ
PCI-DIO-32HS on Windows 7?
Is it possible to use the PCI-DIO-32HS with Windows 7?  If yes, can you direct me to the correct driver to install?
Thank you.
(6,292 Views)
Accepted by topic author aaron.cramer
Hi aaron.cramer
There is a Traditional DAQ driver for Windows 7. The driver does not work for 64-bit operating systems.
This link describes the limitations of the driver and links to the download: https://www.ni.com/en/support/documentation/compatibility/22/traditional-ni-daq--legacy--windows-vis...
Noah | Applications Engineer | National Instruments
(6,267 Views)
Board works under DAQmx, 64 bit Win7
(6,149 Views)
