06-19-2008 05:11 PM
06-20-2008 03:42 PM
06-20-2008 05:50 PM - edited 06-20-2008 05:51 PM
You can set up your digital task and have all of the resources reserved with the data in the buffer of the card so every time a trigger is received, you can have it update. If the trigger is periodic, you can use that signal as your sample clock. A good place to learn how to accomplish this is in examples. The Example Finder can be accessed through the Help menu in LabVIEW. A DAQmx example which may help in this situation can be found browsing by task under Hardware Input and Output » DAQmx » Digital Generation » Cont Write Dig Port-Ext Clk.vi. This example shows how to configure everything and have your data be written to the digital channel when the next clock edge (trigger) arrives. You can also find more information about DAQmx in this article or in the DAQmx Help.
06-20-2008 06:02 PM
06-23-2008 05:33 PM
06-24-2008 02:58 PM - edited 06-24-2008 03:01 PM
06-24-2008 04:45 PM
