Multifunction DAQ
PCI DAQ card and an USB DAQ device in the same computer
I was wondering whether I can install PCI DAQ card (M series) and an USB DAQ device (M series) in the same computer.  If this is possible, do I need to reload the drivers for the PCI card? (I have already installed the USB device)
Palitha
(2,701 Views)
Palitha J
Yes multiple devices on the same computer is not a problem. As far as the drivers are concerned, I have no idea what you are using currently to communicate with the USB device. If you are using NI DAQmx then you should be fine.
Chris
(2,694 Views)
Thanks a lot.  Yes, I am using NIDAQmx.
Palitha
(2,679 Views)
