12-17-2015 04:14 PM
Hi All,
I've gone through multiple PCI-6723 cards we have here and in all cases the second AO 8-31 port to connected to my BNC-2110 box isn't recognize a second device in NIDAQ Measurements and Automation. Also the green LED on the box won't light up so I'm assuming a physical problem. It's not a problem with the cords or boxes, I've switched everything around and the first port is recognized just fine but the second seems to be a continual problem. I wanted to know if anyone had any similar issues, if I'm possibly doing something which keeps blowing out that port? The first port still works fine on all the cards, so I was wondering if this is a common or at least known issue.
Thanks!
12-17-2015 05:43 PM
12-18-2015 02:26 PM
Ok I've got it worked out now based on your comments, so Thanks! I was wrong in thinking it would recognize it as a second device or power on the LED, but while the 2110 box isn't really the best option you can get some functioning connections from the second port (and I only needed a couple). The pinouts from the second port just connect in a somewhat inverse order starting at the AI 0 port and working backwards (so AO 8 = AI 0, AO 9 = AI 1, AO 11 = AO7, etc.). So not the best way to do things but I think it will hold me till I get proper breakout boxes.
