I have been working with the NI PCI‑6562 card in LabVIEW for quite a long time. I would like to use the card to synchronously generate two independent tasks on the same DIO lines. The trigger for starting Task 1 is the first rising edge on PFI3, and on the next rising edge I would like Task 2 to be generated on the same lines 3–6 (according to the Generation Channel List in the Assign Dynamic Channels block).
Could you help me with this? Any hints would be appreciated, because the example VI I am using throws an error. I am attaching the sample VI.
Thank you in advance for your help and suggestions.
Piotr
