Multifunction DAQ
PCI-6289 Troubleshooting
Hello, I have inherited a PCI-6289 in my lab group to run a NI Breakout Box for the purposes of collecting photodetector and trigger data. To do this I have been using a Python script that has worked well until last week. I can no longer run the script or collect data as the terminal tells me it can't find the NIDAQ instrument anymore. I am using the intrumental-lib python module that has worked for the past few months without issue. I believe this is an issue with the PCI-6289 card. If it were an issue with the Breakout Box it would give me an input error that I have seen many times and know how to fix, but this time it fails earlier in the script.
I have checked my drivers and updated them to the latest (NI-DAQmx 18.1). I have also tried transferring the card to another computer with the same results.
Is there a way to diagnose this issue from the PC? I have tried looking through Device Manager but I don't find anything obviously related to PCI-6289. NI MAX doesn't recognise the device but with that only being installed in the latest update for the PC I don't know if it is supposed to show up or not.
Any help is appreciated!
(3,252 Views)
Hello.
Try to unistall NI-MAX (on control panel), DAQmx (control panel too, on NI software) and install DAQmx or VISA to install NI MAX again.
Regards
(3,223 Views)
Accepted by topic author PancakedRivet
Thanks for the advice, I found a computer with a PCI slot that was able to work so I believe it's a hardware issue with PCI slots on the computer I was using.
(3,212 Views)
Hi everyone,
Now I have NI PCI-6730. I want to python program to connect and control signal via PCI-6730
Can you help me.
I don't know how way use it
Thanks in advance,
(1,819 Views)
@ngvhien - it is not ethical to hijack someone else thread for one's own purpose, please create a separate thread unless you face the same exact problem as described by OP.
Anyway, these are some articles to get started with using DAQmx in Python
https://nspyre.readthedocs.io/en/latest/guides/ni-daqmx.html
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Pf1SAE&l=en-US
Santhosh
Soliton Technologies
(1,806 Views)
I am so sorry
(1,800 Views)
