10-26-2007 05:10 AM
10-26-2007 05:15 AM
Hi there,
Thanks for this information. I just wanted to know what code you are using as a basis for these tests? How is the output being updated by the software? What errors are you getting?
Any more information might actually help me get to the underlying reason for this problem.
AdamB
10-26-2007 05:29 AM
01-08-2008 05:34 AM
Hi Marco,
I found this same problem with a Asus PK5-SE motherboard using a PCI-6229 board. Even in MAX, if the AnalogOutput of 1 channel was > 33,000 samples/sec a DAQmx error message of -200016 was generated. (Took me a long time to sort out this problem.)
If I tried a USB-6259 board, other problems occurred, and the board failed to work.
However, if I used a PCIexpress-6259 board, MAX AnalogOutput and my C++/DAQmx program worked perfectly.
Actually, this problem was first reported in Feb, 2006: http://forums.ni.com/ni/board/message?board.id=250&message.id=19597&requireLogin=False.
I understand that Asus is the largest motherboard maker in the world. Why does NI not test ASUS motherboards?
In fact, what motherboards does NI test? I know they test Dells, but what else? Intel motherboards?
Cheers,
Bill
04-16-2008 03:43 AM
Hi
I am having also bunch of problems working on Asus P5K-E motherboard.
Worst is that when I click on the browse button of a path control, Labview hangs, and even sometimes the file explorer.
Here is my configuration :
Motherboard : P5K-E
CPU : I ntel Core2 duo cpu E6750 @ 2.66 GHz
OS : Windows XP Pro SP2
Ram : 2 Go
HD :
01-12-2009 04:16 PM
01-13-2009 04:02 PM
The only solution we found was to throw away the Asus mainboard and by a new one (Intel).
ALL the problems desapeared.
It costed us around 100 hours. Thank you NI.
08-10-2009 05:15 PM
