09-04-2014 11:24 AM
I am writing a pattern using the digital outputs (P0.8-P0.31) and want to trigger a voltage reading on AI16 when P0.31 changes from low to high. Any ideas on how to accomplish this?
Solved! Go to Solution.
09-05-2014 04:27 PM
Have you looked at an example in the LabVIEW example finder? You can export a digital signal to a PFI line on the DAQ board. For an analog input task, you can place a DAQmx Start Trigger VI and choose the source as the PFI line where the digital signal was exported to.
09-11-2014 05:16 PM
Almost what Michael said...
@michael_lewis23 wrote:
Have you looked at an example in the LabVIEW example finder? You can export a digital signal connect your signal from p0.31 using a wire to a PFI line on the DAQ board. For an analog input task, you can place a DAQmx Start Trigger VI and choose the use an external sample clock source as the PFI line where the digital signal was exported to.
Best Regards,
09-12-2014 10:06 AM
Thanks John. That makes more sense. It's not the best solution (all the PFI lines are on the other connector) but I can make it work.
kph
