07-08-2019 12:15 PM
Hi, I have a PCI-6251 card but pretty much no new computer can take a PCI card these days. Is the PCIE-6251 a complete one to one replacement or is there an alternative? Are the drivers for the PCIE-6251 easily obtainable from say LabView 2013? Thanks
Solved! Go to Solution.
07-08-2019 01:43 PM
What do you need to do with the device? The DAQmx driver will cover any of NI's relatively modern boards, including the PCI-6251, the PCIe-6251, and many many more.
I think most users would benefit from a newer X-series (PCIe-63xx) device. You might start by considering the 6351 or 6361 as shown in Table 1 on this page. Other options might be worth considering if you'd like to enhance capabilities in a particular area.
Odds are high that any code you have that runs on the 6251 will also run on any X-series board (as long as the new board has at least the same # I/O channels as the old). I know of one obscure possible exception related to buffered period measurement, but I seem to be one of the few who were adversely (and knowingly) affected. Otherwise, I consider the X-series to be nice improvement over the M-series MIO boards.
-Kevin P
07-08-2019 01:43 PM
It should be a direct replacement. If you are using LabVIEW 2013, I would probably use DAQmx 16.0.1. That is the newest version of the DAQmx drivers that are compatible with LabVIEW 2013. According to the readme, it will work with all forms of the 6251 (PCI, PCIe, PXI, PXIe, USB).
07-10-2019 12:28 PM
The board was previously connected to another DAQ module (I forgot which model) that had a collection of BNC input and outputs and was used mostly to provide analog feedback to a mechanical delay stage. My only concern is how this will play out with existing code and what not.
