08-29-2005 07:28 AM
08-29-2005 11:47 AM
08-29-2005 03:30 PM
09-05-2005 09:39 PM
Dear Ayman K.
Thank you for your help. Actually it is a very good way to remeber.
Here is what you said:
If you are doing Differential measurements, then you would not need to wire anything to AIGND or connect any bias resistors unless the source signal is floating (not reference to ground). As far as NRSE, you need not to wire anything to AIGND when you select NRSE. NRSE references a channel to AISENSE. YOu would need to use bias resistors if your signal source is floating. Otherwise you don't need bias resistors.
Anyway, I am trying to test if my test fixture output sources is a floating signal source or grounded signal source.
Can I determine by testing the differential mode and signle-ended-nonreferenced (NRSE) mode for grounded siganl
sources. If I can not get a good signal on ACH(+) and ACH(-) for differential mode in gounded signal source in differential mode and
ACH and AISENSE for NRSE mode in ground signal source. I can say my output souce of my test fixture is foating signal source..
Many thanks if you can reply promply.
09-06-2005 01:53 PM
09-07-2005 03:38 AM
That means my way to determine the signal source wether it is floating source or grounded source is correct. I need a direct answer.
Thanks!
09-07-2005 11:54 AM - edited 09-07-2005 11:54 AM
Message Edited by Doug M on 09-07-2005 11:57 AM
09-07-2005 08:13 PM
Dear Dough:
Thank you very much!
Why is not always be safe in using RSE method rather than Differential method? RSE is the easiest. What do you mean by safe?
09-08-2005 10:05 AM
09-08-2005 11:04 AM
