01-16-2008 10:37 AM
01-17-2008 12:20 AM
Could you attach/send the link of the VI that you downloaded?
We could probaly suggest better by looking at it
01-17-2008 08:00 AM
01-17-2008 04:04 PM - edited 01-17-2008 04:05 PM
I have looked at the code you provided and from what I can tell if you wish to perform the operations with a single DAQ device you will need to modify the input of the DAQmx create channel VI, the current vi takes the inputs from the front panel and concatenates into a single string. You can replace the set-up for loop with something similar to the screen shot below. The loop structure seems to be doing nothing more than taking the inputs from the user and using it to sync all of the devices. In your case this is not necessary. More examples can be found by going to LabVIEW Help>> Find Examples>>Hardware Input and Output>>DAQmx>>Analog measurements>>Voltage. I hope this helps to clear things up!!
