PCI-6132 Analog input not working
First the computer that is not working:
logisys Fanless PC:
mother board  - Intel 945GME Chipset
RAM -  2 Gb
Operating system - Window XP service pack 3
processor - Intel Mobile Core Duo Processor - T2500, 2 Ghz
two PCI slots
Working Computer: Dell latitude E4300
motherboard - Mobile Intel®  GS45 Express Chipsets
RAM - 3.5 Gb- Window XP service pack 3
processor - Intel Core2 Duo - P9400, 2.4 Ghz
one PCI slot through a magma PCI bridge
Message 11 of 19
(4,058 Views)
Do you have a product number for which fanless one it is. That way we can look at the specs and make sure it should work.
THanks
Nick
Applications Engineer
Message 12 of 19
(4,043 Views)
The logisys fanless PC part number is LG-PCO110FH2
Message 13 of 19
(4,040 Views)
Message 14 of 19
(4,038 Views)
Hey guys,
I am contacting R&D on this and I will let you know what I find out.
Message 15 of 19
(4,020 Views)
This may be a shot in the dark-
Does the fanless PC have an earth ground connection to the chassis? If not, can you try connecting one?
-AK2DM
Message 16 of 19
(4,012 Views)
Hey Analog Kid,
Sounds like your thought was the same as mine.  Unfortunately, grounding does not seem to be the issue here.  However, to answer you question - yes; it is grounded.
Matt
Message 17 of 19
(4,008 Views)
Accepted by nlwagner
Hey Guys,
This is the consensus that I am getting from upstairs. "Comparing the two cards, I would guess the PC just isn't providing enough power on the right lines.
PCI-6254
+5 V ....................................... 0.03 A
+3.3 V .................................... 0.725 A
+12 V ..................................... 0.35 A
PCI-6132
+5 VDC (±5%) ......................... 3.0 A
+3.3 V .................................... 1.2 A
-12 VDC ................................. 70 mA
If the computer can't provide enough current on the line we are using to power the AI systems, it's likely that is causing the railing issues.  I'd be very surprised if a fanless PC could effectively run a PCI-6132 for an extended period of time. "
It seems that you might need to use the working PC, or try another PC to use the S series card with.
Thanks again,
Nick
Message 18 of 19
(3,984 Views)
Thanks for taking the time to look at this. I've been thinking that for a few days that the easy solution is to get a different computer. This just confirms it.
Nick Wagner
NOAA/ESRL/CSD
(303) 497-3924
Message 19 of 19
(3,978 Views)
